Zum Hauptinhalt wechseln
Repair and disassembly information for HP Pavilion 15 Laptop PCs, specifically 15-eh models. They feature 15.6-inch displays, AMD Ryzen processors, DDR4 memory and solid-state storage. Released in 2022.
When I start and log in the screen goes black and won't start anything
Hi, when I turn on my computer and start it, the screen will randomly go black, closing all open applications, and won't let me do anything other than shut it down manually, even when I access safe mode. I'm not sure what the problem is, because besides safe mode, there's no other way to interact with it that I know of.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @gabrielher74473
Random make it difficult but if it stays on long enough when Windows is loaded check in Event Viewer for any Critical, Error or Warning events that may have been logged at the same time the problem started before. Look for events that have the most appearances in the list and then search online using the Event ID and Source information to find out what it means.
Here are some troubleshooting checks that may help determine if it is an OS problem or a perhaps a hardware problem.
  • Is the laptop fan still operating when the problem occurs?
  • Start the laptop and get into BIOS with a working display and check if the laptop stays on for a while and doesn't freeze etc.
  • Download and run this free memory test program from a USB drive inserted into the laptop, (don't forget to change the boot order to USB 1st boot option) You're not so much testing if the memory is OK (although if it passes then that's a bonus) but you're also testing a lot of the hardware functions that are needed to run the program itself. The program is a standalone program so it doesn't require Windows to be loaded to run it. If it works OK without freezing etc then it's looking like a Windows OS problem if not then it's probably hardware.
Please confirm the full model number of the laptop as shown on the product information label on the bottom of the laptop.
War diese Antwort hilfreich?
Bewertung 1
22 Kommentare:
Should I post the referece photo?
von
@nick
I assume you mean a reference photo of the Event Viewer logged entries?
Here's how to post images in your question on ifixit Bilder zu einer vorhandenen Frage hinzufügen
von
@jayeff No. Where the HP S/N is.
von
@nick
Got confused as to who the OP was.
Sorry.
They should know where to find the product information label I hope.
Cheers
von
Hey! thanks for the input. The full model is 15-eh0022la
As for the solutions in the post
-How can I view If there are anyt errors in the event viewer
-the fan appears to still work, as well as any USB devices like mouses and fans
-I don't really know how to get into BIOS mode for this model
I am going to atempt to try the memory test shortly, but I would like to know from the other methods told before hand
Thank you for your help.
von
17 weitere Kommentare anzeigen
Antwort hinzufügen
Gabriel Hernández wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 248
