Zum Hauptinhalt wechseln
A gaming PC is a personal computer specifically designed and optimized for playing video games.
Once power on my PC suddenly off and try to on time and off
Intel Core i5-11400F 2.6 GHz 6-Core Processor
Corsair H60 54 CFM Liquid CPU Cooler
MSI MAG B560 TOMAHAWK WIFI ATX LGA1200 Motherboard
Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Addlink S70 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
Asus STRIX GAMING GeForce GTX 1650 SUPER 4 GB Video Card
GAMDIAS AURA GC1 ATX Mid Tower Case
Cooler Master MWE Bronze V2 550 W 80+ Bronze Certified ATX Power Supply
Recently mother board changed from MSI mag bazooka b560m through warranty. Work fine 1 week. Then this problem came. Repair centers says no issue found. With long rest it works 30 minutes.
Check this link for problem video
https://youtube.com/shorts/Z359sRQYW00?s...
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @shaarimajs
Try performing the paperclip test on the PSU and check if it stays on or turns on and off
If you have a DMM (digital multimeter) you can also check the voltage outputs from the PSU to make sure that they're all OK.
Are the EZ Debug LEDs on the motherboard turning on at all? - see p.34 of the user manual for their location on the board
Initially trying to isolate whether it is power related or the PC is starting and not passing POST.
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
I checked my psu work well. As per service centre all hardware working good. They didn't check my ssd
von
@shaarimajs
How long is it on for before it turns off and then turns on again e.g. does it boot into Windows or not?
If it does how long is it in Windows before it resets?
If it doesn't boot into Windows can you get into BIOS on startup and check if it stays on when you are there?
von
If I give long rest like long week without trying to on it, it boot windows and work approx 1/2 hr. After immediate try if got shutdown PC will not boot to window. It will be like in that video link.
von
@shaarimajs
Try creating a bare bones PC and check if it starts OK so that you can get into BIOS with a display and that it stays on.
Disconnect everything from the motherboard so that all you have is the CPU +CPU fan, ram, PSU, mouse keyboard and monitor connected.
Disconnect/remove everything else e.g. GPU card, SSDs, RGB lights (if any), case fans etc etc.
Just trying to eliminate if it is power related or if it is something else.
You have to start somewhere, especially if it is intermittent
von
I try that one also by remove the Motherboard from case and connect everything except ssd. Can't get display without gpu since my CPU is 11400F (not come with inbuilt gpu)
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Shaarim AJS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 158
