Zum Hauptinhalt wechseln
Informationen zur Reparatur, Demontage und Fehlerdiagnose der Infinix Smart 7 Android-Smartphone-Familie, einschließlich des Smart 7 HD Modells Infinix X6516.
My phone screen sometimes it's difficulty to touch
Especially the right side of the screen become difficulty to touch, fist time I think there's a problem to screen. I restarted my phone then it becomes good but the problem return
Ist dies eine gute Frage?
Bewertung 16
3 Kommentare
It restart on it self
von
Slow problem
von
Ano ang sira pag nag hang ang screen
von
Einen Kommentar hinzufügen
12 Antworten
Hilfreichste Antwort
Display hit problem
War diese Antwort hilfreich?
Bewertung 3
When IAM play free fire game my phone is very hang issue
Bewertung 1
The Infinix Smart 7 does not have a specific screen calibration setting like some other devices. However, you can troubleshoot issues with your phone's touchscreen by removing the screen protector and cleaning the screen, which might improve touch sensitivity. If you're experiencing ghost touch issues (where the screen seems to register touches without you touching it), you can try gently bending the opposite edges of the screen to relieve pressure on the digitizer.
This video might also help.
Bewertung 0
Yes also even restart it self
Bewertung 0
Your phone is likely having a touchscreen responsiveness issue because the problem goes away after restarting but keeps coming back. This usually happens due to a software glitch, a failing touch digitizer, or interference from a screen protector, case, heat, or moisture. Restarting temporarily fixes system errors, but if the right side of the screen continues to be difficult to touch, it may indicate an early hardware problem. You should try removing the screen protector and case, cleaning the screen, updating the phone’s software, and checking if the issue happens in Safe Mode. If the problem still occurs even after these steps, it is most likely a hardware issue, and the screen may need to be checked or replaced by a technician.
Bewertung 0
Not like that
Bewertung 0
You need to change the screen
Bewertung 0
2 Kommentare:
I need to fix my Levi's mobile phone. It needs a screen protector, motherboard, and many other things. Its button is broken.
von
just now by krkr memi Edit Delete
von
Charging system
Bewertung 0
Display lagging
Bewertung 0
Take time to boost
Bewertung 0
Ponsel saya agak nglag
Bewertung 0
1 Kommentar:
Ponsel saya ngelag
von
Ayw ma touch ang screen kahit hnd nag hahang ang cellphone
Bewertung 0
Antwort hinzufügen
Fabiana Samweli wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 24
Letzte 30 Tage: 64
Insgesamt: 1,961
