Zum Hauptinhalt wechseln
Why does the Motorola edge 2024 screen break easily even though it cla
I have been using the Motorola edge 2024 for half an hour, the specification indicated that its screen was resistant to shocks and damage, I fell it off the bed and its screen cracked, So where's the claim that this phone can withstand drops or bumps? I don't know what to do now with a phone with a cracked screen. Sending it in for repair is expensive, so how can I have the confidence to buy more Motorola equipment if what they say about one thing isn't true?The warranty is simple and says it doesn't cover screens, do I have to pay more for just one fall? Now I'm unemployed and worse with a broken cell phone. I don't know what to do because I'm afraid of cutting my face when I stick the phone out.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@jose35185 that screen is just as robust as any other cellphone screen. Sometimes it just has to land on the proper spot and it will crack. Happens all the time and that is where a good case and screen protectors come in handy. The only option you have is to replace the screen with a new one.
To work on it, use the repair manual which you can find on this page Motorola Edge (2024) under the Documents header
War diese Antwort hilfreich?
Bewertung 0
5 Kommentare:
Actually, it isn't as robust as any other. The Edge 2024 has a pretty bad weak point at the end of the power button, all it takes is the slightest bit of pressure in that area, the frame will snap and the screen will break.
von Teilen
@technerd22 is that documented anywhere or is this anecdotal from personal experience?
von Teilen
I've had three Motorola G 2024 screens break in the last year.I had a screen protector and protective case on them, and all three broke in the upper right corner When the first screen broke, I found it was cheaper to purchase a reconditioned phone than to replace the screen so I bought the same model again. But that one also broke. I then purchased another reconditioned Moto G, and it's screen just broke. I don't handle these phones any differently than other phones Ive had in the past. Yes, sometimes I drop my phone, which is why I have the protective cases, but all three of these broke so easily. Frustrating
von Teilen
Well thats all good and fine for the moto g series that you're referring to but the OP is talking about the edge 2024, so this weak point anomaly that you referred to is not going to be what happens on the edge 2024, because the slightest bit of pressure at the end of the power button isn't going to snap an aluminum frame thus causing the screen to crack. I've dropped my edge 2024 many times, sometimes without a screen protector and just the case, sometimes with a screen protector and no case. Every time it came out ok but after the last 2 which were the highest drops out of them all I switched to this wannabe OtterBox case from Amazon from one of those slim minimalist cases that look better. But what ails one particular model of a phone isn't necessarily going to be a problem with a different model from the same manufacturer since different models will have different build materials and whatnot
von Teilen
@seanhinshaw edge 2024 frame isn't aluminum, it's plastic.
von Teilen
Antwort hinzufügen
Jose wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 1,291
