Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für Hunderte von optischen Laufwerken.
Repairing optical drives instead of just replacing
Does anyone have advice for repairing optical drives. I have one that sometimes reads a disk but if I try to burn a disk I get errors. I work in an e-cycle plant and we get quite a bit of them and repairing seems like a better option than just replacing.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from https://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
@jerrywitherite most common failure for something that you describe would be a weak laser. Sometimes increasing the voltage to the laser slightly by adjusting the trimpots (never do that without a meter or you could burn it out). Ultimately replacing the laser would be the only real fix.
War diese Antwort hilfreich?
Bewertung 0
they are so cheep. throw it away and try another.
Bewertung 0
1 Kommentar:
@altonbell40070 the iFixit community frowns upon throwing stuff out just because "they are so cheep". Check on here https://www.ifixit.com/Right-to-Repair to see what this is all about.
von
Charge problem
Bewertung 0
Antwort hinzufügen
Jerry Witherite wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 32
Insgesamt: 438
