Reparaturanleitung, Informationen zur Demontage und Fehlerdiagnose für die kabellose Logitech MX Master 3S-Maus. Erschienen im Jahr 2022 und gekennzeichnet durch die Modellnummer MR0077.
Less than a year after purchasing the MX Master 3S, the left button started to not register clicks (about 2/3 of the time) and shortly after, the right button followed the same issue.
I would really like to have a guide on replacing switches and the parts that fit here.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
This seems to be a very very common issue on these mice. My MX anywhere 3 is doing the same thing with the right click after 4 years where it feels mushy, like something's dislodged.
Because logitech & iFixit have partnered, there are guides on this very website on how to disassemble the mx master 3s, and given the one you want isn't there you can always reference the master 3 guide, since they are very similar.
As for where to find the parts, Logitech isn't selling them here as they likely require resoldering. What you could do however is to open up the mouse, check what the part number is and given you are able to solder, order one yourself & do the repair.
If you don't want to do the repair yourself, there's a chance your local repair shop might do the repair for you since it's a small soldering job. Otherwise i don't reckon Logitech are going to do replacements on that mouse.
Do note, since this is less than a year old, you should be able to claim with logitech given the 1 yr warranty.
4 Kommentare:
I just passed the warranty :( lol.
The opening guide currently on iFixit does not include replacing the switches, nor dose it mention parts that would work.
Logitech has replaced the switch from MX 3 to a drastically different type for MX 3S. I placed an order for a couple of Kail Mute 6 x 6 x 7.3 switches, will update if they fits.
Got some kailh gm 8's ( clicky, not silent ) and soldered them on. Just had to cut off the back leg of the switch and for easier shoving back into the hole, ground down the 2 pins. ( the mouse just went out of 2 year warranty couple of days ago. )
