Sounds to me like you've got two problems.
For the first, I recommend visiting your local department store and picking up some adult sized diapers. This will help you avoid similar mistakes in the future.
For the second, I've got good news and bad news.
The good news is you still have a chance to save your phone.
Use the following iFixit guides to disassemble your phone:
iPhone 4 CDMA
And then use this guide to repair any possible water damage (if you were as drunk as I imagine you must have been it'll have been pretty close to water anyway):
iPhone Wasserschaden reparieren
The bad news is, even with this process, your phone might not have survived its cruel and unusual ordeal. At that point the best thing you can do is reassemble the phone, cross your fingers, turn it on, and hope it comes back to life.
Best of luck.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
