Zum Hauptinhalt wechseln
1.6 oder 1.8 GHz Dual-Core Prozessor, 2 GB oder 4 GB SDRAM, 64 GB oder 128 GB SSD
Battery screws, where to find correct sizes or replacement?
Hi,
I need to buy new battery screws for my MacBook Air 11" Mid 2011. The replacement guide at Ifixit says there should be:
  • Two 5.2 mm T5 Torx screws
  • One 6 mm T5 Torx screw
  • Two 2.6 mm T5 Torx screws
However, almost all listings says that a set of two 2 mm T5 Torx screws and three 4 mm T5 Torx screws will fit. Or something similar sizes at other websites. They market this at compatible with both 11" and 13" models.
My question is two-folded
1) Is it possible to use these replacement screws (e.g. https://garmade.com/products/battery-scr...)?
2) If not, where on earth can I find the correct screws!?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
I can't speak on what Garmade is offering as I don't see the sizes listed.
The next best option is in the UK TheBookYard - Macbook Air 11" Screw Set - Battery (10-15) as you can see the sizes are listed out.
War diese Antwort hilfreich?
Bewertung 0
The screws available at Garmade are also fine.
Bewertung 0
Antwort hinzufügen
Jonas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 128
