Zum Hauptinhalt wechseln
This model of MSI is identified by the MSI logo in the bottom center on the device's front cover and by its model number/name MSI Force GC30 V2. The MSI Force GC30 V2 was released on September 3rd, 2021.
Is there anyway of fixing drifting in the joystick of the controller?
i got the controller five months ago still in the box, and the joystick doesnt respond when i try to "go up"
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
That's a bummer to have a controller with a drifting joystick, especially when it's practically brand new! Since the joystick isn't responding when you try to go "up," it might not be a typical drift issue where it moves on its own, but rather a dead zone or a connection problem.
Here are a few things you can try to troubleshoot and potentially fix the issue with your MSI Force GC30 V2 controller:
Basic Troubleshooting:
  1. Recalibrate the Controller: Many operating systems and gaming platforms have a built-in option to calibrate controllers. This can sometimes resolve issues with stick responsiveness. Check the settings for your PC or console.
  2. Restart Your Device: Sometimes, a simple restart of your computer or console can resolve temporary glitches that might be affecting controller input.
  3. Check the Connection: Ensure the controller is properly connected, whether it's wired or wireless. If it's wireless, try replacing the batteries or ensuring it's fully charged. If it's connected via Bluetooth, try unpairing and pairing it again. If it's wired, make sure the USB cable is securely plugged into both the controller and your device.
  4. Update Drivers/Software: Outdated drivers or software for your controller or operating system can sometimes cause input issues. Check for and install any available updates.
More In-Depth Solutions:
  1. Clean the Joystick Area: Dust, debris, or sticky residue can sometimes interfere with joystick movement. Try gently cleaning around the base of the joystick with compressed air or a soft, dry cloth. Be careful not to spray any liquids directly into the controller.
  2. Check for Physical Obstructions: Inspect the joystick and the surrounding area for any physical obstructions that might be preventing it from moving freely in the "up" direction.
  3. Test in Different Applications/Games: See if the issue persists in other games or applications. This can help determine if the problem is with the controller itself or specific to one piece of software.
  4. Controller Testing Software (PC): If you're using the controller on a PC, there are third-party applications that can help you test the input of each button and joystick axis. This can give you a clearer picture of whether the "up" direction is being registered at all.
If the above steps don't work, it might indicate a hardware issue with the controller. Since you mentioned it's only five months old and "still in the box," it might be worth considering the warranty.
  • Check the Warranty: MSI products often come with a warranty period. Check your purchase documentation or the MSI website to see if your controller is still under warranty. If it is, you might be able to get it repaired or replaced.
  • Contact MSI Support: Reach out to MSI's customer support. They might have specific troubleshooting steps for your controller model or be able to guide you through the warranty process.
Hopefully, one of these steps will get your joystick working correctly again! Let me know if you try any of these and what the results are. We can explore further options if needed.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Matilde Marques wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 40
Insgesamt: 486
