A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Is the water being pumped out of the machine when it is filling (can you hear the drain pump working?) or is it leaking out at the bottom of the machine?
Hi @katrina98494
What is the model number of the washer?
von jayeff
