Zum Hauptinhalt wechseln
iPod Hi-Fi ist ein Lautsprechersystem, das von Apple Inc. entwickelt und hergestellt wurde. Es erschien am 28. Februar 2006 für den Einsatz mit jedem iPod-Digitalmusikplayer. Das iPod Hi-Fi wurde bis zu seiner Einstellung am 5. September 2007 im Apple Store verkauft.
Gerät reagiert nicht weder mit iPod noch mit externem Plattenspieler
Gerät war die ganze Zeit am Netz, keine Reaktion, auch nicht nach Reset
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
@martin87593 are you saying that your A1121 doe not show any sign of life? If so then the first thing to check would be the power supply. Here is how to take it apart
"Pull away speaker mesh grill. Using a sharp knife or similar carefully lift off the black facia plate. The facia is about 1mm thick and is glued to the speaker plate. Take care not to bend it as you rip it from the glue- bends make it harder to replace in position later. With the fascia removed you reveal eight dark-brown screws that hold the speaker plate to the box and silver screws that hold the speakers in place.
After removing the 8 screws the speaker plate can be lifted from the box. Several cables with plugs are very short and will pull the plugs out of their sockets if you lift the speaker plate away. It may be better to first remove the 4 screws from the central speaker- lift it to one side and reach in to carefully note where the cables attach and remove them gently with tweezers or needle-nose pliers.
Note-the speakers are very fragile. The cables are- 1) Large 4-pin to central speaker. 2) medium 2-pin to right speaker 3) medium 2-pin to left speaker 4) Miniature 3-pin 5) Miniature 6-pin to fascia LED and remote sensor. Reconnecting these cables when you put the speaker plate back in place is very difficult through the speaker hole" from here
Once you have it open, take some good picture of the power supply and post those with your Question. That way we can see what you see and hopefully find a solution for this issue.
Hope this helps, good luck.
Translation
@martin87593 meinst du, dass dein A1121 überhaupt nicht mehr funktioniert? Wenn ja, solltest du als Erstes die Stromversorgung checken. So kannst du das Gerät auseinanderbauen
"Zieh das Lautsprechergitter ab. Heb die schwarze Frontplatte vorsichtig mit einem scharfen Messer oder so ab. Die Frontplatte ist etwa 1 mm dick und mit der Lautsprecherplatte verklebt. Pass auf, dass du sie beim Abziehen nicht verbiegst, sonst lässt sie sich später schwerer wieder einsetzen. Wenn du die Frontplatte entfernt hast, siehst du acht dunkelbraune Schrauben, mit denen die Lautsprecherplatte am Gehäuse befestigt ist, und silberne Schrauben, mit denen die Lautsprecher fixiert sind.
Nach dem Entfernen der 8 Schrauben kann die Lautsprecherplatte aus dem Gehäuse gehoben werden. Mehrere Kabel mit Steckern sind sehr kurz und ziehen die Stecker aus den Buchsen, wenn du die Lautsprecherplatte abhebst. Es ist möglicherweise besser, zuerst die 4 Schrauben aus dem mittleren Lautsprecher zu entfernen, ihn zur Seite zu heben und vorsichtig zu prüfen, wo die Kabel befestigt sind, und sie dann vorsichtig mit einer Pinzette oder einer Spitzzange zu entfernen.
Achtung: Die Lautsprecher sind sehr empfindlich. Die Kabel sind: 1) Großes 4-poliges Kabel zum mittleren Lautsprecher. 2) Mittleres 2-poliges Kabel zum rechten Lautsprecher. 3) Mittleres 2-poliges Kabel zum linken Lautsprecher. 4) Miniatur-3-poliges Kabel. 5) Miniatur-6-poliges Kabel zur LED-Blende und zum Fernbedienungssensor. Das Wiederanschließen dieser Kabel beim Einsetzen der Lautsprecherplatte ist durch die Lautsprecheröffnung sehr schwierig. Von hier
[Bild|238564]
Wenn du das Gerät geöffnet hast, mach ein paar gute Fotos von der Stromversorgung und häng sie zu deiner Frage. So können wir sehen, was du siehst, und hoffentlich eine Lösung für das Problem finden.
https://de.ifixit.com/Anleitung/Bilder+z...
Ich hoffe, das hilft dir weiter, viel Glück.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Martin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 54
