Zum Hauptinhalt wechseln
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
Leaking Heat pump water heater, AO Smith HPTU-50N130
Chris Stillman
***1 minute ago
UPDATE: The leak is coming from the bottom device. I'm looking into this manual if that pulls out, etc. Any input is welcome.
Hello, I woke up to a nice puddle of water underneath the water heater. It is spraying water out from the inside. The water is literally spraying out from behind the section in the photo attached.
I may be in over my head on this one but figured I'd check in with you guys!
Thank you!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
PS, water and power are off.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@chrisstillman
How old is the unit?
According to the brochure there's a 10 year "limited" warranty on the heat pump.
Might be worth checking to see if it's covered if <10 years old.
Here's a service manual that may help.
See the section about changing the element.
To order parts you may have to use this link
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Yes sir! Thank you again! My wife and I are going bonkers trying to find receipt. It's under 5 years old, never mind ten!
I'll get back to you as I learn some things, etc. Thank you again!
von
@chrisstillman
See if this is applicable to your model.
von
Antwort hinzufügen
Chris Stillman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 126
