Zum Hauptinhalt wechseln
Der größere von Apples MacBook Air Laptops mit Doppelmikrofon und 802.11ac Wi-Fi Konnektivität.
not sure what BATTERY replacement is good for this MacBook Air?
Hi everyone, I'm new here and know nothing about this sort of stuff.
My Macbook air does not work unless it is attached to a charger. Sometimes even whilst being charged, the battery is on red. I can't afford a new laptop and would like to replace the battery.
Can anyone advise me what battery is needed for the following Macbook air? Do 2014 or 2015 Macbook air use the same battery as the 2013 Macbook air model?
MacOS Big Sur
11.7.10
8gb 1600 Mhz DDR3
Serial Number: C02MG358F6T6
Thank you in advance.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
A1369 & A1466 MacBook Air 13" Models 2010-2017 are using the same Model #A1377, A1405, A1496
Install coconutBattery to see the actual condition of your battery but I think your battery is at the end of its lifespan, but a good idea to double check nevertheless. (Take a screenshot of the report and post it in your question (edit question & add image) so we can confirm.
MacBook Air 13" Mid 2013 Akku Austausch
War diese Antwort hilfreich?
Bewertung 2
7 Kommentare:
@livfe thanks for your answer. I can't download coconut battery as my MacOs version is too old.
von
@aishaot Scroll to the bottom of the CB website and you can get versions that are for older systems :) Your MB Air can support OS 11.7.10 Big Sur.
von
@livfe thanks, I finally managed to download coconut battery. I've attached the screenshot on my post. Based on that info, what battery do u suggest I should get? tia
von
@aishaot Go to finder (in prefs under locations select to show your device, then navigate to the system library folder and there should be 3 or 4 files .com.apple.power*, delete them and empty the trash, restart, and check CB again..... Batteries I have bought before were the A1405 if I remember rightly, strange it says poor condition yet 100%.... try the method stated before, also do a PRAM reset also.
von
@livfe thanks. I think I'll buy the MacBook Air 13" (Late 2010-2017) Battery regardless, hopefully it is the right battery for the model
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Aisha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 62
Insgesamt: 500
