Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für Hunderte von optischen Laufwerken.
Lite-On iHAS124 Tray not ejecting, even with manual eject
My tray on my DVD drive won't eject, even if I use the paperclip manual eject, the drive itself moves out, but the tray doesn't move. This is a problem since the disassembly guides for the similar iHAS324 requires that the tray be ejected.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hello, I had the exact same issue yesterday, with the manual eject not working.
How I fixed it
I managed to get it to work this morning by using a slightly bigger, sturdier paperclip and applying more force.
There shouldn't be any chance of damaging internal components, just make sure to push straight into the hole, not angled up or down.
Also, you may have to hold the drive to ensure it doesn't move. I took mine out of my PC case so I could handle it easier.
How the manual eject works
The manual eject lever, which you push on when you poke a paperclip into the hole, swings left, pushing a rail across to unlock the tray and push it out slightly.
I can attach images if you want, I didn't on this reply in case it delays my answer being posted.
Electronic ejection issue
The issue with the electronic ejection on mine seems to be that the tray ejection belt (as I call it) is too loose. I'm going to try put it in boiling water to shrink it (as I seen on other forums).
I hope this helps, just give it a good few tries, with decent force, and hopefully it will work.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
While helpful, I'm pretty sure that on manual eject, the drive *was* moving out of the way with manual eject to let the tray leave, but the tray itself doesn't budge.
Additionally, if I remember correctly (The computer I was testing the drive with is having issues and therefore I can't currently test the drive), on an electronic eject, the issue is that the tray *does* move, but only very very slightly because it can't escape the drive (Perhaps it's blocked by something? I can't get far enough into it without getting the tray out to check.)
von
I kid you not, it looks like there was a bit of a slope on the manual eject mechanism that was confusing me, after a bit of struggling trying to strike it, it finally ejected the tray!!! This was the answer!
von
Antwort hinzufügen
PWnS2009 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 306
