You installed a new hard drive...make sure it is still detected by the BIOS.
Make sure the hard drive is listed first in the BIOS boot order.
Try unplugging all USB devices before booting.
Reinstall GRUB using a LiveCD. Instructions are too lengthy to write here...go to this page and read the section titled .. "Fixing a Broken System - Reinstall from the LiveCD ".
https://help.ubuntu.com/community/Grub2/...
This solution works for some people ...
1. LiveCD boots into a blank screen.
When you see the boot menu when you boot LiveCD, hit F6 and select the “nomodeset” option.
2. Boots into a blank screen after install.
Reboot and keep your finger on the “SHIFT” key till you get the grub menu. Highlight the first entry and replace “quiet splash” with “nomodeset” . Hit CTRL + X to continue booting. Once logged in install the latest Graphics drivers. System -> Administration -> Additional Drivers
When you say the same thing happens even when booting from LiveCD....try changing the boot order in BIOS to cd/dvd first...perhaps it is still trying to boot from the hard drive even when the Live CD is inserted?
Out of curiosity..have you tried any other boot disks..like Hirens, or Barts PE..or even a Windows install disk?
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
