Allainguillaume, there are a few possibilities. Check the capacitor, make sure it is not leaking or bulging. Check the flash unit itself to make sure that the light is working. There are two fuses on the Flash PCB, make sure that those are showing continuity with your multimeter. The flash unit replacement number is Vek0L84 and it is available at multiple places for around $20. Here are the instructions for the flash unit. Remember to discharge the flash capacitor.
CAUTION:
1. Be sure to discharge the capacitor on FLASH PCB.
2. Be careful of the high voltage circuit on FLASH PCB when servicing.
[Discharging Procedure]
1. Refer to the disassemble procedure and remove the necessary parts/unit.
2. Put the insulation tube onto the lead part of Resistor (ERG5SJ102:1kΩ /5W). (an equivalent type of resistor may be used.)
3. Put the resistor between both terminals of capacitor on FLASH PCB for approx. 5 seconds.
4. After discharging confirm that the capacitor voltage is lower than 10V using a voltmeter.
Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare
Flash's PCB problem maybe occured when i hit the camera on my leg..
I was trying to fix an message error "turn on, turn off" due to dust on the lens inside switch, because i did not want to dissassemble it to clean. I read this method on the internet, it helped but maybe i hit too hard!
von Allainguillaume
The only way to see what is going on after "getting slapped" to hard' is by opening it up and take a look at the flash unit.
von oldturkey03
