Zum Hauptinhalt wechseln
Why is my laptop start heating under 5 minutes
why is my laptop starts heating under 5 minutes i want solution for this problem
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
2. Poor Cooling or Dust Build-up
Symptoms: Heat from keyboard/base, fan always on or unusually loud.
Causes: Dust blocking vents or fan, Thermal paste dried out, Faulty or weak cooling system (especially in older or thin laptops).
Fix: Clean vents with compressed air, Use a cooling pad, Consider repasting CPU
War diese Antwort hilfreich?
Bewertung 0
Well High Background CPU Usage can also be the reason for this kind of issue so i will suggest you to Open Task Manager (Ctrl + Shift + Esc) → check CPU usage and end the unnecessary tasks.
Bewertung 0
If your laptop heats up within 5 minutes, it could be due to dust buildup, blocked vents, or a heavy background process. Try cleaning the vents, placing it on a hard surface (not a bed or pillow), and checking Task Manager for any apps using too much CPU. If it still heats up, you might need to get the fan or thermal paste checked.
Bewertung 0
Antwort hinzufügen
Vansh Sharma wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 152
