Won't come on screen when turn on
Screen go blank after window xp pop up
Ist dies eine gute Frage?
Here is a link to a copy of your service manual. Good luck.
War diese Antwort hilfreich?
First try to check your power supply using a voltmeter if your getting the appropriate voltages or not then try to re-install the windows by following steps:
In case you dont have a disk you can install windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start booting from USB).
Step 8- follow the on screen instructions to complete the windows installation.
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 920
1 Kommentar
Does your screen remain properly visible when your computer stays on? Does your screen stay visible when you access the BIOS?. I would try a Linux Live CD and boot from that. See if your screen remains visible. Right now it does sound like a Windows problem more than a computer problem. Have you tried to safe boot windows and checked your drivers?
von oldturkey03
