Zum Hauptinhalt wechseln
Der Kia Rio der dritten Generation debütierte am 1. März 2011 auf dem Genfer Auto-Salon und basierte erneut auf dem Hyundai Accent.
The Faulty Air Conditioning is not blowing cold cold
  • My car's air conditioning system stops blowing cold, although it has enough gas. Can you give me any advice on what the problem may be and how to fix it?
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Hi @jeff14318
When you say, "...stops blowing cold..." does this mean that is is blowing cold air and then stops or that it doesn't even start blowing cold air when first turned on?
If it doesn't blow cold air at all, can you hear the compressor clutch engaging when the A/C is turned on indicating that the compressor is operating?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The first thing to check is to ensure the system has enough refrigerant. It sounds like you did this, so I will assume you did the obvious and eliminated it early. Given the system works, the fuses and relays are probably fine, so we can skip that as well. If you want to check the fuses and relays, that's fine, but they're probably not blown given it has power. Use a DMM like this: https://www.lowes.com/pd/Klein-Tools-Dig...
Also, I would check the cabin filter for dirt and replace it before going deeper - sometimes this will help especially if the filter is original (or very close to it, and it's only been done once or twice prior) and it's cheap enough at $10-20.
While not a hard requirement, running an all-system scan tool on the car will give you a clue. A basic scanner will not suffice for Hyundai/Kia cars with A/C issues; you need one that can read the proprietary codes. Either buy one or take it to a shop and pay them to scan it and give you a report of the codes, including the actual code (Ex: B (Body) and C (Chassis) DTC codes). You will likely need to pay for this, but if you want to obtain codes cheaply, then this is the way to go. I own an XTOOL scanner, which can do this, but it's also not cheap - it can range from $250-$300. Unless you do the work yourself or have a German car like a Mercedes or Audi on your shortlist, buying this for a heavily depreciated Kia from the era where they were more infamous for oil consumption/Theta II motors blowing up the cost of the scanner is high relative to the value of the cars once they hit 100k miles :/.
The common suspects (without codes) on Hyundai/Kia platforms are the blower resistor (though this is more associated with A/C issues where the refrigerant is fine but nothing works), or bad blend doors. If you decide to try a blind fix, I would recommend trying the blower resistor if you want the "easy fix," but it's generally not an issue unless the resistance is low - this is where a good multimeter comes in handy, as you can check it against what it should be.
As an example as this is not an exact figure this is what you want to set the meter to when you check:
If you can and the module isn't potted, it's probably a single resistor - maybe two - on a PCB. read the resistors directly from the PCB. If you can't do this because it's sealed, some trial and error is needed.
You can also try the blend doors first - but if you do, do them all, especially if you're unsure which one is faulty. Now if you know the left driver is bad and the rest are fine, you can replace that one, but be aware that it's a big enough job that I usually recommend doing them in pairs, such as this: Bad left driver > Do both on the driver side. Get ahead of it or you may be kicking yourself.
If neither of these fixes works, you may have a leak in the system or a bad compressor that has seized up. Put some dye like this in the A/C condenser, run the car for a bit, and see if you see any dye: https://www.amazon.com/Interdynamics-Cer...
If there are no leaks, I would check the compressor for leaks and seizure issues.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Also get your 609 so you can get the good stuff. The retail self sealing cans are getting priced out like they were priced by a high floor manager or they have some BS like stop leak which poisons the system and you need to replace the dryer, condenser and compressor and on top of that pay to have the lines cleaned if you contaminate the system. If it has a valve in the system things like stop leak poison those as well :/. $20-40 and you can pass it open book and buy 3lb+ of the good stuff and get more for the same money as a consumer pays. They’re doing it now more often or selling butane clones because of California and Washington.
von
Antwort hinzufügen
Jeff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 32
Letzte 30 Tage: 150
Insgesamt: 1,703
