Kenmore 665/purchased in 1997 wn't completely dry after running dry 4x
I have done the dry cycle 4x and some dishes still are not dry
Is there a filter on my model 66513761690 and if so, where is it located
Ist dies eine gute Frage?
These are the only models that I found that begin with 6651376.....
Check if one of the model numbers listed is there on your model.
Are you using Rinse Aid in the dishwasher?
Are the dishes hot when the dishwasher has finished but the dishes are still wet?
Is 665.16761690 the model number of your dishwasher perhaps?
If so the only filter in the dishwasher is the pump filter - p/n 9742968 but this would only mean that the dishes would possibly still be dirty i.e. dried food particles left on them etc if the filter was partially clogged and not that they'd still be wet.
Is there still a lot of water left standing at the bottom of the dishwasher when it has finished?
War diese Antwort hilfreich?
I hadn't used rinse
I have not used rinse aid in a while
Dishes are hot but very wet. No water in the bottom.
I usually shake out some of the stuff to flick off water and try to run dry cycle multiple times. It used 2 take 2x but now even 4x isn't enuf
And it sb a 3 instead 665.13761690
Where does the "3" go in the model number?
Click on the blue 6651376...... link in my answer above to see all the dishwasher models beginning with "6651376????", as you can see the number you posted isn't there.
You are right, 665.15761690 is my model
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 110
1 Kommentar
Can you double check your model number? I'm not seeing any results for the model you have listed. There are some results for 665.137, but nothing that matches the remaining digits.
von Jerry Wheeler
