How to add more ram to the laptop
How to increase ram to my pc
Ist dies eine gute Frage?
Hi @n00bgamers
There is only one memory slot in the laptop so depending on which laptop variant you have will depend on whether the laptop supports a maximum of 20GB or 24GB of ram.
The i3 UMA variant has 4GB of on board ram which is not removable so all you can add is a 16GB DDR4 2666MHz SODIMM module giving 20GB in total i.e. 4 +16
The i5 and i7 variants have 8GB of onboard memory which is not removable so all you can add is a 16GB DDR4 2666MHz SODIMM module giving 24GB in total i.e. 8 +16
Go to the bottom of p.15 (p.16 of 77 pdf) of the service manual to view the procedure to remove replace the secondary¹ memory module.
¹ The primary memory is the onboard non-removable memory
War diese Antwort hilfreich?
https://www.youtube.com/watch?v=PXmXZlUt... looks like it's got a good set of instructions to follow.
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 340
