Zum Hauptinhalt wechseln
Identify screw from DJI Mini?
Hi all - can someone tell me where this long shafted screw came from/needs to go back into DJI Mini (2 SE)?? (the longer screw in the images.)
I used an iFixit guide to open up the drone and glue a broken gimbal arm, and this screw fell out. From the point I have disassembled the drone, I can not locate where the screw came from and presumably needs to go back!
I have not found a mini repair guide that identifies this screw either.
Any advice? Thank you!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
  • the longer shoulder bolt is a propeller bolt
  • the smaller ones look like the two screws on the inside of the battery compartment.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks! (I didn't realize it had slipped out of propeller. Duh.)
von
Glad i could help a second set of eyeballs can go a long way :)
von
Antwort hinzufügen
Billy Moon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 44
Insgesamt: 232
