Display not output by graphic card
I plug my graphic card in slot when I plug display output cable ( hdmi ) but I screen the no device connected shows even I change my cable also
Ist dies eine gute Frage?
Do you have a second monitor or system to verify if the display is working or even try a second system to make sure the video slot is not damaged. If the card is still not sending a video signal then you've isolated the issue to the card and will need to dig into the cards logic, that will require component level diagnostics.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 314
