Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für das Google Pixel 9 Pro, angekündigt im August 2024. Modellnummer GR83Y.
purchasing motherboard flex cable for pixel 9 pro
Hello, I need to replace the motherboard flex cable for my pixel 9 pro due to water damage. I do not see this on the website, is this available for special order? p/n G949-01094-00. Please advise asap. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I'd highly recommend professional repair for any and all liquid damage repairs.
If you insist, however, you can find the parts you're looking for here edit: currently not available however According to the Mobsen vendor rep I spoke with the OEM part will be made available "soon" Most new pixel fpcb parts are out of stock and in short supply as of July 2025
I'd suggest harvesting parts from a donor or "for parts not working" device if the part is urgently needed.
Also, any liquid-damaged devices should be immediately powered off and placed into a bag with silica gel desiccant ASAP
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
Hi @adr_daniel
Searching through the link you posted it looks like they don't carry that part either.
Moderator
von
I looked at the link that @adr_daniel included, and agreed, the piece that I need is not available. So, I guess I'll have to continue searching. It's a pretty simple piece, and I see plenty available for the Pixel 9 on ebay and other sites, but not the 9 "pro". I wish they would have made these the same!!!!
von
@joes64319 @jayeff I looked into it deeper, typically, Menus carries all the parts you would need to repair almost every issue. However, replacement flex printed Cricut cable assemblies for the entire Pixel 9 lineup are in short supply or not yet available from the manufacturer.
This is unfortunate news and I'm highly disappointed google is the expectation to industry norm in parts availability.
I'd suggest harvesting parts from a donar or "for parts not working" device if the part is in urgent need until the rest of the parts for the pixel 9 pro are made available to repair part vendors.
von
Great advice, thank you!
von
Antwort hinzufügen
Joe S wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 322
