Zum Hauptinhalt wechseln
Anleitungen für Reperaturen an der Nintendo Switch OLED, die 2021 vorgestellt und veröffentlicht wurde.
Switch doesn't turn on when left joy-con is attached
I have a rather peculiar issue and am uncertain if my assumption is correct. The console was purchased second-hand, so I am not entirely sure what happened.
Initially, I discovered by chance that the console only turns on when completely powered down and the left Joy-Con is not attached to the console. (at this point, I didn't know, that the Joy-Con was the issue)
Since today, I've also had the problem that the Joy-Con charges but is no longer recognized in handheld mode.
After cleaning the contacts, the Joy-Con seems to work normally in handheld mode again, but now I have a problem with turning it on. I was able to get it to work without any problems for a while, but unfortunately that's no longer the case.
Would replacing the left rail help in both cases?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
@dan0 what do you make out of this one? Any chance you can help the OP with this?
von
Sure do :)! Thanks!
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
Well, is either joy-con related or it’s related to the left rail on the console!
Did you tried another joy-con to test? If yes, then you do need to replace the left rail.
If not, I would do this first so you can troubleshoot way easier!
Guide: Nintendo Switch OLED linke Joy-Con-Sensorschiene austauschen
Please let me know how it goes!!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Schokio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 50
