Zum Hauptinhalt wechseln
The Craftsman Generator 580.326300 is a single-cylinder, air-cooled engine generator, capable of producing a maximum power of 6300 watts and a surge power of 9100 watts. This page contains detailed information and guidance for repair and maintenance of this model, including its specifications such as engine horsepower, fuel capacity, and oil type recommendations.
How to remove battery
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Since the battery is buried underneath the gas tank, you have to take the tank off to access it.
If you try to just loosen the nuts, you'll never get them tight again because the bolts will never have enough traction to tighten back up.
I've had mine for 21 years, I have sunk money into maintenance (parts aren't cheap), but I feel that having something that I know is good instead of buying another one is money in the bank.
It's still a PITA to do all that, but you should take the tank off and clean it anyway, I only use ethanol-free gas and filter it before it goes into the tank, but gas eventually breaks down (if you don't stay on top of it) and it starts turning into something that resembles something your wife made for you on your first sit-down meal together...
Be sure to disconnect the hose going to the carburetor from the gas tank, so I would also advise you doing this when it's low on gas.
Take good care of all of the parts (especially the grommets that the gas tank sits on), they will probably be brittle, and you might have to change those out too (not cheap...though I did replace mine anyway the last time out).
I'm surprised you haven't had to change it out by now; I'm now on battery 'three'.
I really like the unit, though I believe that B&S (who are the ones who actually built it) had two engineers working on the project and they hated each other...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Neale Sanderson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 38
