Zum Hauptinhalt wechseln
Why my laptop can’t go past the blue screen!?
My laptop wasn’t turning on totally so I opened it up with a YouTube tutorial the laptop can turn on now but it can’t go past the blue screen send help
Update (08/03/25)
Previously, I had an issue where the laptop wouldn't turn on, and I discovered that the power cable inside the PC was broken. This cable, which is black, is responsible for transporting power to the PC when the power cord is plugged in. Fortunately, I was able to fix it, and now the laptop turns on without any issues.
This is an old laptop btw but it was working fine until I encountered a problem. It started with a 'PC ran into a problem, we'll restart for you' message, followed by a black screen with the Windows icon and a 'repair in progress' message. However, instead of completing the repair, it directly booted to the blue startup menu.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
@tshepodhlamini there is usually some writing on this blue screen, if it is a Windows screen? What does it say? Post a picture of it with your Question. What tutorial did you watch? What was the original issue that you "fixed"? Bilder zu einer vorhandenen Frage hinzufügen
von
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@tshepodhlamini this very much looks and sounds like a failed Windows startup related to corrupt system files. The recovery is most likely failing because OS can't find the system files. At this point I would suggest that you do a fresh install of your OS (whatever version Windows you are using)
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I got a USB with Windows 7 but the laptop was Windows 10 is it still good!?
von
@tshepodhlamini give it a try and see if you can install if over the previous install. You can always update after
von
Antwort hinzufügen
Tshepo Dhlamini wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 133
