Zum Hauptinhalt wechseln
Why does my pto click when key is turned, but blades won't engage?
I checked wiring, belts, spindles, the fuse behind seat. All good. I did put a 30 amp fuse, instead of 20. I was cutting, stopped. Started mower back up, no blades. I checked safety switches. For some reason I'm having to jump my battery since this has happened. I sure could use any advice and I thank yall
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
With mine I had a fence wire wrap around the blades, after cutting off the wire the blades won't engage.
von
Einen Kommentar hinzufügen
1 Antwort
If your battery voltage is to low then your clutch won't fully engage.
Check your battery voltage normal battery volts should be 12 to 13 volts
If battery volts are ok then test the volts at the clutch plug in with key on and pto engaged should be just slightly less then the if OK then your then your clutch might be the fault
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Matthew Mooney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 167
