Zum Hauptinhalt wechseln
Das Xiaomi Poco X3 Pro ist ein Einsteiger-Smartphone von Xiaomi, das im März 2021 veröffentlicht wurde. Es ist mit einem 6,67-Zoll-IPS-LCD-Bildschirm und einer 48-MP-Hauptkamera ausgestattet und läuft mit dem Qualcomm Snapdragon 860.
My phone got blank while using, now its not turning on!
i was using instagram , then suddenly my phone turned off. i thought it was due to battery but i tried charging , turning it on , resetting but its not working . i even changed its display but its not working . any solutions !
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I'm sorry to hear about your POCO X3 Pro. This is a known and frustrating issue with this particular model, often referred to as the "dead boot" problem. The fact that it turned off suddenly while you were using an app, and now won't turn on even after charging and changing the display, points to a deeper hardware issue.
Here's a breakdown of the problem and the potential solutions:
The Root Cause: CPU/Motherboard Issue
The most common reason for the POCO X3 Pro's sudden death is a faulty connection between the CPU (System on a Chip) and the motherboard. Over time, due to heating and cooling cycles, the solder joints holding the CPU can become weak or crack, causing the phone to fail. This is a widespread manufacturing defect with this model.
Since you've already tried basic troubleshooting like charging and even a display change, the problem is almost certainly not the battery or the screen.
Potential Solutions (from most likely to least likely to work for you):
  1. Professional Repair (Reballing):
    • This is the most effective and common solution for the dead boot problem.
    • A skilled technician will carefully remove the CPU and RAM from the motherboard, clean the old solder, and "reball" them (apply new, high-quality solder balls) before resoldering them back onto the board.1
  • This process effectively re-establishes the connection and brings the phone back to life.
    • What you should do: Find a reputable repair shop that specializes in motherboard-level repairs. Ask them specifically if they have experience with the POCO X3 Pro dead boot issue and "CPU reballing."
  • Warranty Service:
    • If your phone is still under warranty, this is your best option. POCO has extended the warranty for the X3 Pro in some regions due to this known issue.
    • Contact a POCO or Xiaomi authorized service center. They should be able to replace the motherboard or repair it for free under warranty.
  • Advanced Troubleshooting (Requires technical skill):
    • Some users have had temporary success by applying heat to the motherboard, a process sometimes called "baking" or using a heat gun. However, I strongly advise against this. It's extremely risky, can damage other components, and is often only a temporary fix. It's not a reliable solution and can make a proper repair impossible.
What You've Already Tried and Why it Didn't Work:
  • Charging: Since the motherboard is the issue, it can't manage the charging process or power the device, so charging won't help.
  • Resetting/Booting: The phone can't get past the hardware failure to even begin the boot process. Holding down power and volume buttons won't work if the core components aren't functioning.
  • Changing the Display: The display is just an output device. If the CPU and motherboard aren't working, they can't send any signal to the screen.
In conclusion, given the nature of the POCO X3 Pro's dead boot problem and the troubleshooting steps you've already taken, the most realistic and lasting solution is to take it to a professional for a CPU reballing or to a service center if it's still under warranty.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for the answer man …
But
There are no experts near by ….
Is there any ways that i can repair at home ..?
As if i order the MB online and then install it my self .. i can take the of youtube and online sites ….will that work ..?
von
Antwort hinzufügen
chris brown wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 53
Letzte 30 Tage: 263
Insgesamt: 685
