Zum Hauptinhalt wechseln
Panasonic VCR with VCR Plus+, with Hi-Fi stereo sound and VHS recording. The Omnivision line contained many models of programmable VCR.
Not powering up, fuse is good
This is a Panasonic Diga DMR-ES30V
Given to us. It won't power up. The eletricial sourse is good, the cord is good, the fuse is good.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Try leaving it plugged in for a few minutes, if it turns on after a few minutes, it may be a bad power supply capacitor, so you may want to open it up and look for obviously blown capacitors, if the problem still persists, then replace all of the capacitors in the power supply. this worked for my Panasonic DMR-EZ48V, just be carful as power supply capacitors can hold a dangerous voltage.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Tim Dobbs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 94
