Zum Hauptinhalt wechseln
Reparaturinformationen und -anleitungen für die lang ersehnte Neuauflage des beliebten MacBook Air, ausgestattet mit Intels Core i5-Prozessoren, einem aktualisierten Retina-Display und zahlreichen weiteren Änderungen und Updates, veröffentlicht am 7. November 2018.
Finding the correct model battery
Hello,
I am trying to repair the battery of my wife macbook air. I do not understand which battery model I need to buy since this one: MacBook Air 13" (Late 2018-Early 2020) Battery is talking about late 2018 and she bought it in May 2018. Is that correct? Should I aim for the 2017 model? I couldn't even find the mode name in the settings.
(sorry for the bad quality of the screenshots 😇)
Thanks for your help.
Replace a 4379 mAh battery compatible with MacBook Air 13" (Late 2018-Early 2020). 49.9 Watt Hours (Wh), 11.4 Volts (V). Bild
Produkt
$99.99
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
The laptop should have a A**** Number on the case. Probably the back in tiny writing. Search for the A number replacement battery or open it up. The battery has its own A number so you'll know which one you need.
von
Model Number of the 2018-2020 MBA is A1932.
2017 (A1466) models are completely different in every way.
von
@livfe - The A (or EMC) number isn't always the best reference as Apple also defines their Batteries with a A number that is not a one to one relationship with the given system. And some systems can be labeled with an A number but don't share batteries or other parts. Don't shoot the messenger here! Shoot Apple!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Here's the needed battery MacBook Air 13" (Late 2018-Early 2020) Battery and here's the guide to put it in MacBook Air 13" (Late 2018-Early 2020) Battery
Produkt
$99.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
carlo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 204
