Zum Hauptinhalt wechseln
Nintendo Handheld-Spielkonsole veröffentlicht im Februar 2011, identifiziert durch die Modellnummer CTR-001.
bottom lcd purple in some spots replacement didnt fix
so i had dust under my digitizer which was causing the digitizer to not work so i cleaned it with 70% isopropyl alcohol which im sure isnt a high enough percent but i didnt think of it much and i dont think i waited long enough for it to evaporate because when i turned it back on it started bugging out moving on its own and stuff so i disconnected the battery to wait till the morning and then i put the battery back in and the bottom screen is purple and the digitizer stopped working so i just went to aliexpress because im broke and i bought a replacement screen along with a digitizer and they seemed nice quality better than oem so i put everything together made sure all ribbon cables were seated correctly and i turned it on to see if it worked my digitizer worked but my screen is still displaying multiple colors as purple i dont have any pictures of it but when im at the home screen the border around the apps are almost entirely purple and some of the background
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
So you replaced the screen already and it’s doing the exact same thing as the original did?
I hate to say this, but then it’s most likely motherboard related… is everything okay on there? Please clean everything with isopropyl alcohol (98-99%). If possible, please sent some photos. Otherwise a morherboard replacement is required.
Please let us know how it goes and if you need guides!
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
okay sorry for the late respose but i did clean everything that had to do with the screen and i also made sure that all the connectors were seated properly although that didnt seem to fix the issue
von
Could be CPU/GPU related... I know that sometimes the Nintendo DS lite could have experience the same issue. In the worst case, a motherboard replacement is required... Sorry.
von
yeah its alright its only cosmetic which im thankful for so ill probably just use it until i buy a n3ds but thank you for your help man i appreciate it much love brother
von
Always happy to help :)!! If you have any other question, please let me know! Wish you the best!
von
Antwort hinzufügen
swaggyp wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 68
