Why is it that my engine is hard to start and when it starts it cut ou
Why is it that my engine is hard to start and when it starts it cut out when high gears are engaged or when climbing a hill
Ist dies eine gute Frage?
if it idles ok it is not the air leak it is more likely the float level cutting off to early had same issue sputters acts like spark plug it is carb if jets arew clean check manifold for leaks if no power check your clutch belt too. also the elits have a over flow tube from carb that will evaporate the gas in carb if sittiing more than 3 days people are putting fuel filter on extra causing less gas to carb make sure tank isn't to rusty will be cleaning carb slow jets alot. don't run a hot or cold plus like in the snow weather will caucing rich issues
War diese Antwort hilfreich?
My bike Has No Any signal in the display and not start and not coming current
Meri Activa atak atak kar chal rahi hai yani ki main start kar raha hun to start hone mein bhi thodi dikkat Le rahi hai itni jaldi start nahin ho rahe aur na theek se itni jaldi start ho rahi hai aur maine Jaise bhi karke start kara uske bad mein Main gadi aage badha raha hun thodi aage jaane ke bad mein FIR matlab ki jhatake maar rahi hai
Jaise ki Tel khatm Ho Gaya Ho Mera aise jhatake maar rahi hai to Main Kya Karun
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 67
Insgesamt: 1,169
2 Kommentare
I need more information to answer.
von Parsa Tsr Teilen
The gas lines are dirty and do not flow enough gas, yes it could be in the carburetor, Cleaning may help or just running new gas.
von om1gc Teilen
