Zum Hauptinhalt wechseln
Volume button not working
Volume button are not working while pressing it
Ist dies eine gute Frage?
Bewertung 2
7 Kommentare
How to change volume button
von
@abhijitdebnath Does the existing answer not answer your question? If not, what's different about your question from the original?
von
Volume button repair
von
@abhi31782 See the Most Helpful Answer below; your issue has already been addressed.
von
My volume button not working
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@pranav55998 could most certainly be a bad volume button flex. To replace this and since iFixit does not yet have a guide for that, use the one from here It is written in Spanish so use a browser that does the translating for you, if needed. The volume button flex is readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Bewertung 1
Well check for any sort of physical damage near the volume button area if recently your phone is drop down so that can also cause the damage on the button and also check for the latest software version update sometime an outdated software version can also cause these kind of issue as well.
Bewertung 0
Antwort hinzufügen
Pranav wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 111
Insgesamt: 812
