Zum Hauptinhalt wechseln
Die erste große Überarbeitung des 3DS durch Nintendo wurde im Oktober 2014 in Japan und im September 2015 in Nordamerika veröffentlicht. Der 3DS 2015 bietet verbesserte 3D-Funktionen, einen C-Stick, neue interne amiibo-Unterstützung und ein neues Set an Schultertasten.
Broken SD card reader - replacement needs special tape?
I needed to replace my SD card reader as I broke the original. The replacement part didn't have the metal piece that is pictured, so I tried to transfer the old piece to the replacement but ruined the tape in the process.
What is this tape and where do I buy it? I'm really confused by it, seems to be black double sided tape with silver metal tape in the middle. I'm not sure if it's meant to be stopped or helping conduction, it's really confusing me and I just need to buy something so the replacement can be installed.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Speculating here,
The black tape is probably used to bond the metal RF shielding to the SD card reader, preventing RF interference, it's commonly used as insulation, and sometimes provide correct spacing between parts, for that you can likely use any double-sided, non-conductive adhesive tape for example Tesa 61395 Tape (also really useful for adhering screens to bezels)
Custom cut rolls of Tesa 61395 double-sided tape for repair. Bild
Produkt
Tesa 61395 Tape
$8.95
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
So, is it just any black tape or is there something else? It seemed like the original tape had metal in it too. Is the RF shielding the metal part? Sorry I just have no clue, I just know replacement parts didn't include the metal part so I'm unsure how needed it is.
Comments on Reddit mentioned it being thermal/conductive tape but didn't mention it they meant only thermal conduction OR if they meant electrical conduction, some mentioned grounding.
I'm just unsure what the metal part is doing and so what exact tape I need - I'm just confused by what seems like silver metal in the tape.
von
Electrically Conductive tape makes some sense to me, as it seems the metal part could be connecting to the motherboard for an electrical ground, looking at the photos in the ifixit guide
Nintendo 3DS 2015 SD Kartenleser Austausch
have you tried installing the replacement reader without the metal or tape?
if it works without it, its likely just shielding, if not it would be a ground connector and needs to be connected.
von
Antwort hinzufügen
AnimeDeamon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 331
