Zum Hauptinhalt wechseln
May 2019 mfg date Model no.XL2540-B 244hz 1ms Gaming monitor
Double image on Zowie 240Hz
Hi im having a double image problem on my zowie monitor, ive tried changing the cables and its not from the gpu other monitors work fine even w the same cables used on the zowie, cant send it to warranty cause it was from a freind and its already past it as well, the only videos i can find of fixes are from people cutting out the connections on the monitors pcb, would like to know if anyone has had thsis problem before if they had found a solution that doesnt require blocking the conections on the pcb.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hello man i have the same issue with mine
https://www.reddit.com/r/Zowie/comments/...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Manuel Nunes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 225
