Zum Hauptinhalt wechseln
Das iPad Air (5. Generation) wurde am 8. März 2022 angekündigt. Es ist mit dem M1 Chip und 5G ausgestattet.
Slow charging battery after replacement
I recently changed the battery on my iPad 5th Gen. (A2588). I ordered the replacement Part from ifixit (Model A2288 Battery for iPad). The battery works but it doesn't fast charge. It tops out at 12 W instead of 27 W that i see with the old battery.
The ifixit battery number is A2288, the Original battery has the number A2742.
Is there a trick or a software lock?
Replace a 7606 mAh model A2288 battery compatible with iPad Air 4, iPad Air 5, iPad Air 6 11" and iPad 10. Bild
Produkt
$59.99
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Your iPad 5th gen uses battery A1484. The one you got (A2288) is not the right part, so the charging controller limits it to ~12 W. There’s no software lock — just a hardware mismatch. Contact iFixit and ask for the correct battery (A1484).
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I think you missunderstood something. I have a iPad Air 5 Generation (A2588) not a iPad 5. But i Think you're correct with the missmatched hadware. It's just odd that the replacement battery is advertised as compatible with the iPad Air 5.
von
Antwort hinzufügen
gartenzaun wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 37
