Zum Hauptinhalt wechseln
My charger port is loose and not charging
I've had this phone for a while and idk if it's from use but I need to know should I get it repaired or something else.(any help will be much appreciated)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@zacargentum since it is loose, it may just need to be re-soldered. Of course it is also possible that it had broken traces or it may even be a bad Sub_board. I would suggest to change that bord since the repair is fairly straightforward and the cost is really not that expensive. Use this guide Samsung Galaxy S24 USB-C-Anschluss und Tochterplatine tauschen for the repair.
War diese Antwort hilfreich?
Bewertung 1
Before you get it repaired attempt to clean out the charging port first, gently use a can of compressed air or a wooden toothpick or you could use a toothbrush to gently get into the charging port to get out any debris. If this fails you may have to get a repair.
Bewertung 0
Antwort hinzufügen
Zac Argentum wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 24
Letzte 30 Tage: 79
Insgesamt: 332
