Zum Hauptinhalt wechseln
Reparaturanleitungen, Support und Problemlösungen für das 2022er 13-Zoll MacBook Air, ausgestattet mit Apples M2 Chip. Erscheinungsdatum 15. Juli 2022, Modellnummer A2681
Top Left Corner touchpad not clicking down
Having an issue with a 2022 MacBook Pro'13 M2
My trackpad no longer produces a mechanical click in the top-left corner. It still detects touch in that area, and the cursor tracks normally everywhere.
What I’ve observed:
  • Using the TrackWeight app, overall pressure seems off, which makes me think it’s a pressure/mechanism issue.
  • I can press the surface down in the top-left, but it doesn’t register a click.
  • Clicking works everywhere else, and if I press in the middle, the left up button clicks as expected.
What I’ve tried:
  • Restarted the laptop.
  • Performed resets (including the “paper method”).
  • No change after any of the above.
Question:
Do I need to replace the touchpad, or is there an adjustment/repair that can fix this?
Update (08/20/25)
Also i forgot to mention when i press down the middle i am able to click the button
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Some liquid spillage could have gotten under the top glass messing up the capacitive sensor. Sadly, it sounds like you'll need a new TouchPad MacBook Air 13" (A2681, 2022) Trackpad and here's the guide MacBook Air 2022 (M2) Trackpad tauschen. This is one of the easiest to replace! The older models required you to take the battery out.
Replace a damaged or malfunctioning trackpad compatible with a model A2681 MacBook Air M2 2022 laptop. Bild
Produkt
$89.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Leo Fratu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 29
Insgesamt: 187
