Zum Hauptinhalt wechseln
Der erste frontgetriebene Wagen, der von Volvo nach Nordamerika exportiert wurde
My hood don't open
Hello, how are you? My car's hood won't open! When I pull the internal lever, only one side of the hood locks releases, while the other remains stuck. Could someone help me?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@davifarias try and have a second person push down on the side where the hood does not open. That may free the stuck hood. You could also try and use a pair of vise grip pliers to pull the cable a little harder and further then the actual hood release does while someone pushes down on the hood. Once you do have it open, check the "bumper" for the hood. You may need to adjust it so your hood is being "pushed" up further then it does now, when you close it.
You could also see if something like this as well as the write up by user "boxpin" on here will work for you.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Davi Farias wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 165
