Zum Hauptinhalt wechseln
Reparatur-, Demontage- und Fehlerdiagnose-Informationen für das Moto G Stylus 5G, ein im Jahr 2023 erschienenes Motorola-Smartphone. Identifizierbar über die Modellnummer XT2315.
How to get into edl mode on moto g stylus 5g 2023 XT2315-1
I need files on the phone but it won't go into fastboot, edl mode and decryption is my only option. I don't know where the test points are so i hope someone has a test diagram or a way to identify them. please and thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I know I am too late.But it will be helpful for someone else.So I don't know the test points but you can make edl cable .Just remove the plastic of type c cable and remove the covering over black and a green wire.Now hold the volume up and down simultaneously and short the black and green cable and now plug in the USB cable .Just wait for 3 to 4 seconds and remove the short by separating the black and green wires and you will be in edl mode Also you can download the blank flash file for this model on lolinet website .My phone hard bricked and went into edl automatically but at that time file was not working.So I tried above method and went into edl mode by this method and file worked and fastboot is now working I flashed the firmware and working fine
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Than you!! This instruction to enter EDL Mode worked on my first try. I've spent days learning and attempting different methods. Yours worked Great!!
von
I also have the same challange
Bewertung 0
Antwort hinzufügen
indieun sata wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 105
Insgesamt: 705
