Zum Hauptinhalt wechseln
Reparaturanleitungen, Support und Problemlösungen für das 2022er 13-Zoll MacBook Air, ausgestattet mit Apples M2 Chip. Erscheinungsdatum 15. Juli 2022, Modellnummer A2681
MacBook air M2 A2681 not power on just webcam green light
I have bought Mac Air M2 but when plug cable in they did not power on and so try Shift + Options + Comand + Power On , somes time green light of WebCam is ligth but still this and not power on
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Are you trying to say you can not charge the MacBook?
von
Einen Kommentar hinzufügen
1 Antwort
The Green LED on the FaceTime camera is telling you the SMC reset you attempted worked! But that's just by luck as the systems battery still has enough residual power to do the reset.
You need to get a USB-C power meter to place inline with your charger to visually see if the system is even taking power.
As you just bought it I would recommend you return it letting the seller address the problem or just get your money back. It's a strong likelihood the Battery is bad and/or the logic boards charging logic has failed needing deeper repairs. That bargain may end of costing you more in the long haul!
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
@danj yeah you right, 400$ fot 16GB Junk but can not return ,
Maybe I will take to the repair shop and consider more
von
Antwort hinzufügen
kuannnkkua wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 24
Insgesamt: 113
