Zum Hauptinhalt wechseln
iPad Air 5 Home Button Different Size
I ordered the iPad Air 4/5 Power Button Cable for my iPad Air 5 (the 2022 M1 gen).
I went to install it and realize it's a different width than the original that came out. Did I order the wrong thing or is there some trick to installing this?
Replace a scratched or malfunctioning power button on the top edge of an iPad Air 4 or iPad Air 5. Bild
Produkt
$39.99
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I would contact the iFixit Store as it's clearly not the same part. On your order sheet will have the information to contact them and I would also post this image with your response or point to this question.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Update - there was a small pice of plastic that was still fixed insides the chassis housing. Once that popped out, I realized the actual opening is the same size.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Travis B wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 157
