Zum Hauptinhalt wechseln
Crank no spark to coil replaced fuel pump and coil packs
Crank no spark replaced fuel pump and coil packs after being ran empty and sat up for a year
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@luda10284 you are really not giving us enough information. It would be great to know the year as well as your engine size. Going by you sparse description of the issue with no spark and no fuel pump activity the issue sounds like a failed crank position sensor. Check and change your sensor and see what you get.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
2012 Hyundai accent gle
Was ran out of gas was told that fuel pump was replaced along with coil packs and battery getting fuel up front don't know engine size it's a small 4 cylinder car just helping out a elderly neighbor when I can ordered two parts crank and cam sensors just in case just trying to cover all my bases
von
@luda10284 i would start by replacing the crank position sensor.
von
Antwort hinzufügen
Luda wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 218
