Zum Hauptinhalt wechseln
The Olympus OM-1 was released in 1972 as a revolutionary 35mm SLR, offering a professional-grade, fully mechanical system in a body significantly smaller and lighter than the competition. It featured a bright viewfinder and unique controls, such as the shutter speed dial located around the lens mount rather than on the top plate.
Maintenance question for OM-1N
I picked up a near mint OM1n from ebay, and i really want to keep it in mint working condition but where i live (island nation) there are quite literally zero shops that specialize in vintage repair/maintenance cameras, let alone Olympus systems. And i dont feel like sending it overseas.
My question is basically this, is there any guide/video tutorial out there that shows and explains a complete CLA process for the OM1 or similar cameras? Im aware im no technician but i can follow specific instructions on my own risk, specifically what kind of lubricants/grease to use, when & on which parts, how to disassemble exactly whats needed and put everything back together. I tried youtube but it doesnt go much further than light seal replacements and prism foam cleaning.
Basically the most basic maintenance a professional would do to prolong the life of the camera.
Or at least as much as a regular person with normal precision tools can perform at home.
Thank you!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You can find the repair manual for your camera online as a PDF from a few sources. Scan example here's the older version Olympus OM-1 service manual here's the rest of the manual grab the last one gets into lube OM-1 & OM-4 maunals
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
now where is a copy for the OM2n ?
von
@om1gc - The mechanicals are the same across the OM-1 series. Only the metering and flash circuits are a bit different.
von
@om1gc see if the manuals on here Olympus OM-2 under the documents tab will work for you.
von
Antwort hinzufügen
DBCooper wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 61
Insgesamt: 377
