Zum Hauptinhalt wechseln
Looking for a capacitor VIM E144575 8uf +\— 5% 250vac.50/60Hz -20~70C
VIM PART # E144575. 8uf +\-5%. 250vac 50/60Hz. -20~70C
Description : black box. 2 prongs on top of box with a metal piece with circle cutout at back of box (maybe it’s where a screw would go to hold it in place, but I’m sure that the prongs would hold it?). The replacement for this has wires instead of prongs and 450 vac. I don’t know if this would work.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @hollanga
As long as the capacitance is the same value i.e. 8µF then having a higher voltage rating is OK to use. If the voltage rating was <250V AC then it wouldn't be OK.
Found this supplier who has an 8µF 250VAC capacitor if you prefer. Scroll down to find 8m250Vcube w/2 Terminals & Foot, (see images of types of capacitors in the list). It shows the dimensions as well.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Hollanga wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 27
Insgesamt: 141
