Zum Hauptinhalt wechseln
Informationen zu Reparatur, Demontage und Fehlerdiagnose der Geek Bar Pulse E-Zigarette.
I stuck q tip in the mouth piece
Trying to remove dirt i stuck a q tip in the mouth piece after this it taste burnt and wudnt pull at all
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The mouthpiece is only snapped in place. You can remove it by grasping it with a pair of pliers and twisting it hard to the side. Once you have it off you should be able to clear any dirt or obstructions in it.
When you go to replace it, pay attention to which way it goes. One side has two horizontal tabs, while the other side has a vertical alignment line, so you have to match up that line with the correct side. It may be hard to push back in place, but brute force will eventually get it reseated. The housing seems to be pretty sturdy so don't worry about breaking it.
This video shows how to open it up (and refill it if you're interested in that aspect).
GEEK BAR vapejuice refill hack - YouTube
War diese Antwort hilfreich?
Bewertung 1
You probably pushed one of the components down into the tank to far. Best solution would be to open it up same pull it back into alignment. You could try with some fine point tweezers, but will likely still have to open it up. There's a guide for disassembly on here.
Bewertung 1
Antwort hinzufügen
Dayna Carmack wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 34
Letzte 30 Tage: 167
Insgesamt: 1,978
