Zum Hauptinhalt wechseln
Repair and disassembly guides and support for wall oven appliances.
How to change the temperature and cooking settings knob on Candy oven?
The knob on my wall oven which is from the manufacturer Candy was loose and now has been ejected and removed from its place. The knobs have a push-in/out feature. I need help on how to fix it.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Hi @nickolaosa77822
What is the model number of the oven?
von
Candy sprinter is the model of the oven.
von
@nickolaosa77822
Here's an article that shows how to find the model number
von
Here is what I see in the oven:
33700878 12350041
Mod: FPP609XL
Type: MR04
Based on the info listed above I looked it up in the link you sent and I still could not find the exact model number
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @nickolaosa77822,
Here's the service manual for your model and serial number oven i.e. FPP 609 X L - 33700878 that may help
It has an exploded parts layout diagram, schematic diagram and also a parts list.
If you need to replace the part, locate the part number for the part in the manual and then search online for the part number to find suppliers that suit you best.
Here's just one supplier that has parts for your model just to give an idea of the cost of the parts.
Here's the switch (part # 90 in the parts diagram) that I think you're referring to.
Here's a list of other suppliers of the switch that may suit you better. Note part # 91201719 is the same as part EGO 42.09001.018
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks a lot @jayeff, the information provided is really helpful, will take the time to find the right part for the kitchen stove I need and see how I can repair it.
von
Antwort hinzufügen
Nickolaos Atsaloglou wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 99
