Zum Hauptinhalt wechseln
Samsung hat ihre S23-Serie auf dem "Unpacked"-Event am 01.02.2023 veröffentlicht. Das neue Galaxy Book3 und die Galaxy Book3 Pro Laptop-Serie wurde auch auch auf dem Event veröffentlicht.
moisture or foreign material in your charging / uSB port
MyS23 while connecting to a cable for charging shows a message that it has moisture or foreign material in the charging / USB port.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Start with cleaning your charging port. Use 90% or higher concentration isopropyl alcohol, an eyeglass cloth and a thin, non-metallic pick such as a toothpick to clean the inside of the port. Examine it carefully with a magnifying glass, ensuring it's sparkling clean.
Be sure you try another charger and cord, as defective parts can also cause that message.
If none of the above helps, you may have to replace the charging port. Like most Samsung phones, your charging port is mounted on a separate daughter card that is (relatively) easy to replace and usually inexpensive. iFixit has a guide giving you step by step instructions on how to do that yourself.
Samsung Galaxy S23 USB-C Port and Daughterboard Replacement - iFixit Repair Guide
A cursory search turned up many suppliers who carry that part, including AliExpress and eBay; choose one that suits your price and availability requirements.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thank you for the detailed explanation . First 2 options I already tried. Let me try with the rest of this. Appreciate your prompt response
von
@swaminatha90772 That's what I would do if it was my phone. Please let us know how it all turns out; your experience may well help the next person who comes along with the same problem.
von
Antwort hinzufügen
Swaminathan Ramasubramanian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 260
