Zum Hauptinhalt wechseln
The RCA 22” DECK215R is a full HDTV with model number M215HW03. Repair of this device requires special, nonconductive tools.
They have power but only color blue appear
No character appear only blue color
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
No character appear
von
are you saying that your screen is blue
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
What the blue screen usually means
  • Input issue: TV isn’t receiving a signal → blue screen appears as a default “no signal” background.
  • Backlight/T-con/main board problem: If the screen lights up but no image is drawn, one of the boards may have failed.
  • Menu missing: If even the TV’s on-screen menu doesn’t appear, it’s likely a hardware issue, not just an input problem.
Quick checks (no opening required)
  1. Test with multiple inputs
    Try HDMI, AV, or coax. If all show the same solid blue, the issue is internal.
  2. Bring up the on-screen menu
    Press Menu on the remote or TV panel.
    • If the menu appears: input source problem.
    • If the menu does not appear: likely T-con or main board.
  3. Power cycle
    Unplug the TV from wall power for at least 1 minute, then reconnect.
  4. Check backlight
    In a dark room, shine a flashlight at the screen while it’s on. If you faintly see images, it means the backlight is working but video is missing.
Common hardware culprits
  • T-con board (connects main board to LCD panel) → common cause of “blue lit screen, no image.”
  • Main board (signal processing) → if menus don’t display at all.
  • Loose LVDS cable → ribbon from main board to panel.
⚠️ Since you mentioned repair requires nonconductive tools, you might be considering opening it. Be aware:
  • Discharge capacitors before working inside.
  • Avoid touching panel connectors with metal tools.
  • The M215HW03 panel is fragile; cable reseating should be done gently.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Benjie amante wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 36
